aviator
Posted: Fri Mar 19, 2021 3:47 am Post subject: Engine Replacement |
Hi Folks,
one simple question. Can I replace the engine U712 with an U709 (GU75C)? The original engine broke and needs to be replaced.
Thanks in advance
Nicholas |
Posted: Fri Mar 19, 2021 11:34 am Post subject: |
| Which SB? |
aviator
Posted: Fri Mar 19, 2021 3:51 pm Post subject: |
| SB6 |
aviator
Posted: Sun Mar 21, 2021 4:48 pm Post subject: |
| No one? |
Posted: Sun Mar 21, 2021 5:45 pm Post subject: |
| Can't recall the differing engine codes (and presumably neither can anyone else) so what exactly is the new engine your trying to fit?? |
aviator
Posted: Sun Mar 21, 2021 6:46 pm Post subject: |
Thank you!
It is a Suzuki GSX-R1100W yom 1995, GU75C with a serial number starting with U709. U712 seems to be the serial number for engines fitted into the SB6 originally.
I am not a Bimota expert but I have got that bike on the bench for engine replacement. |
Posted: Sun Mar 21, 2021 9:58 pm Post subject: |
| In that case the water cooled 1100 engines are all basically the same.... |
aviator
Posted: Mon Mar 22, 2021 8:29 pm Post subject: |
I have found a lot of spare engines but only one(!) so far having the extra mount points which seem to be mandatory on that model.
Anyway, thanks for pointing in the right direction.
If anyone can provide a suitable engine please do not hesitate to contact me
Nicholas |
