Zeus
Joined: 04 Aug 2023 Posts: 7 Location: Andalucía, Spain
Posted: Sat Sep 09, 2023 10:38 pm Post subject: Help: DB5 air filter. |
Greetings.
Can you tell me some brands and their reference of the DB5 filter?
I can't find the manuals, the air reference and the information I find in the stores is not clear to me.
Is the air filter the one fitted to the Multiestrada or the Super Sport?
I know that some of you have set up the MWR Performance Air air filter Bimota DB5 MC-130-00
But I am looking for the brand and model-reference of the original, or of other brands.
There are some from the K&N brand?
Thank you |
Posted: Tue May 07, 2024 10:05 am Post subject: |
| Its just a piece of foam cut to the specific size for the airbox for the DB5....Simply buy a sheet of RAMAIR dual density filter foam....and you can cut with scissors a new filter....and still have enough left for 2 more....you can download for free the Owners manuals, spare parts manuals and Workshop manuals direct from the Bimota factory website.... www.bimota.it |
Quackers
Posted: Wed May 08, 2024 5:03 pm Post subject: |
2Bims is right Juan. That's exactly what I did. Keep it simple  |
Quackers
| 2Bims is right Juan. That's exactly what I did. Keep it simple! |
Zeus
Posted: Thu May 09, 2024 10:47 am Post subject: |
Thank you so much for the answers. I already have the two MWR air filters. I will initially try replacing it with the first one, and later the other, which is installed on the lid. If anyone has put any of these filters, I would appreciate it if you could give me your opinion. The second type recommends touching the engine map.
Open Airbox Airfilter DB5R / DB6R / Delirio (Referencia: MC-130-0
(Remove original filtercover of the airbox and screw the MWR open airbox filter to the airbox tight with the original bolts)
https://www.racingairfilters.eu/product/open-airbox-airfilter-db5r-db6r-delirio/
Performance Airfilter DB5R / DB6R / Delirio (Referencia: MC-130-00)
(Replacement filter for original filter with much better sealing and protection for all DB5 and DB6 models , no modifications needed)
https://www.racingairfilters.eu/product/performance-airfilter-db5r-db6r/
For the future, I'll use what you tell me. Nothing of the original model appeared in the manuals. |
Zeus
Zeus
Posted: Thu May 09, 2024 10:48 am Post subject: |
-Open Airbox Airfilter DB5R / DB6R / Delirio (Referencia: MC-130-0
-Performance Airfilter DB5R / DB6R / Delirio (Referencia: MC-130-00)
Posted: Thu May 09, 2024 1:14 pm Post subject: |
| You should be OK to just fit and forget....its a "warning" which is for legal purposes....like "smoking is bad for you"...I did the cover replacement on my Tesi3D using MWR......I had opened the end can by removing the baffle and felt it needed more air.....be CAREFUL though....every year if you can...check its still well oiled...allow it to become too dry and it WILL disintegrate and break up and be fed into your engine...they come pre-oiled in a sealed bag....Remapping wouldnt be possible unless you had the programme....the correct connecting lead...and the correct 1990's microsoft operation system to run the programme..>Windows XP.....nothing newer works... |
