dougk
Posted: Fri Jul 08, 2011 5:25 pm Post subject: YB11 end can...another post |
I know there is a post re putting a zx12 can on the bike but whilst i wait for my bodywork to return..... does anyone know what fits the YB11 as it is very quiet and the down pipes and exup valve piece weighs a ton?
Or would it be easier to visit a pipe manufacturer and get one fabricated?
thanks in advance
Doug _________________ 1992 CBR900 and a 2002 YB11 |
CBar
Posted: Fri Jul 08, 2011 8:56 pm Post subject: |
I don't know for sure, but it looks like a pre-'98 YZF 1000 exhaust would work. The bend/length appear to be similar in pictures.
I have owned a few 5-valve Yamaha's. I recommend keeping the EXUP and just using the slip-on because of the engine's valve overlap. I have tried other syatems and I could never get the bike to run like I wanted. I could improve one end of the power band, but I always lost on the other end.
It should be easy enough to core the exhaust. You might even be able to buy a carbon sleeve for it, depending on the diameter.
This guy has different exhaust options. Reduction bushings to make mufflers fit different size pipes, custom mufflers, replacement carbon sleeves, etc.
http://www.blackdragonexhaust.net/id8.html
another:
http://www.areapnolimits.com/products/custom.php |
Posted: Fri Jul 08, 2011 11:16 pm Post subject: |
As far as a can goes you just need to know the diameter and have a link pipe to suit. I reckon you'll find it's a fairly standard ThunderAce system so get a can to fit that and maybe fettle it as needed. Probably better to go for an oval or trioval so it doesn't touch the swingarm. _________________ Don't read everything you believe |
Posted: Mon Jul 11, 2011 11:35 am Post subject: |
As far as a full system goes , I tried a nice 98-2001 Akropavic R1 system, all looked good in the pictures, assembled it, look good and weighed about 1/10th of the YB11 system, offered it up to the bike, bit of giggery pokery with the pipes, all bolts/studs located, jobs a good un. Spanners out , tighten the head studs, oh dear, before the headers clamp up the pipework hits the oil filter. Bollocks, such a nice looking system , and only
600 on sale. Akropavic do list but don't do the thunderace system any more, so its down to a one off system me thinks. |
Posted: Mon Jul 11, 2011 1:14 pm Post subject: |
You could probably have the system moddified to fit, I guess it would be the two middle headers fouling the oil filter. _________________ Don't read everything you believe |
dougk
Posted: Mon Jul 11, 2011 1:41 pm Post subject: |
Thanks guys
I will go the modified can route first...
the front pipes weigh a ton (they were blasted clean, exup valve unstuck and repainted by the bike shop) _________________ 1992 CBR900 and a 2002 YB11 |
Posted: Wed Jul 20, 2011 4:30 pm Post subject: |
Mine uses a Two Brothers carbon race can off a ZX12R with a custom link pipe.
Only issue i had is with a pillion and the way the rear pegs are constructed they flex in a little when pillion loads them and during riding the rivet on the can gouged the swing arm a little.
So I got the pillion a bus pass, much cheaper. . . . ..
few pics here http://s188.photobucket.com/albums/z143/oilphiluk/YB11/ _________________ 03 YB11, 03 Aprilia RSVR Edwards, 94 Ducati Superlight III, 95 Honda NC30, 04 Ducati 999S, 91 kawasaki KR1-S C2, 91 Ducati 851 USD Strada, 89 ZXR750H1, 90 ZXR400H1, 205 16v Rally Car, A6 2.7TDI Avant, STM R1 engined Phoenix |
dougk
Posted: Thu Jul 21, 2011 1:50 pm Post subject: |
thanks for this
who made up the link pipe? as I will go this route
... I have re-insured my bikes with no pillion now so it should not be a problem. _________________ 1992 CBR900 and a 2002 YB11 |
Posted: Thu Jul 21, 2011 2:40 pm Post subject: |
EDITED
I believe these peolple did it, Zorstec, Unit 2, Commercial Mills, Wharf Street, Shipley BD17 7DW. 01274 587004 or 07870 406482 (Andy)
zorstec@aol.com .
You'd have to take the bike to them, so a local specialist fabricator should be able to do the work i would have thought
Phil _________________ 03 YB11, 03 Aprilia RSVR Edwards, 94 Ducati Superlight III, 95 Honda NC30, 04 Ducati 999S, 91 kawasaki KR1-S C2, 91 Ducati 851 USD Strada, 89 ZXR750H1, 90 ZXR400H1, 205 16v Rally Car, A6 2.7TDI Avant, STM R1 engined Phoenix |
Posted: Fri Jul 22, 2011 8:27 am Post subject: |
above post edited _________________ 03 YB11, 03 Aprilia RSVR Edwards, 94 Ducati Superlight III, 95 Honda NC30, 04 Ducati 999S, 91 kawasaki KR1-S C2, 91 Ducati 851 USD Strada, 89 ZXR750H1, 90 ZXR400H1, 205 16v Rally Car, A6 2.7TDI Avant, STM R1 engined Phoenix |
zombie
Posted: Thu Aug 04, 2011 11:22 pm Post subject: |
DougK please can you post pix of the bike and the exhaust system as it sounds like a very interesting set up upgrades you have done.
How did you set up your open exhaust.
My YB8/exup setup ran fine with a fully open silencer, but it tended to run rich due to carb wear and tear. The YB11/Thunderace had some mods to prevent this I believe.
Cheers,
Zomb |
