Posted: Sun Nov 09, 2008 5:58 pm Post subject: SB6R |
SB6R carbs, complete and unmessed with please. Must be loads out there, lying about doing nothing |
Posted: Sun Nov 09, 2008 6:30 pm Post subject: |
Just had a quick look at a set of gsxr1100 M Mikuni 40mm carbs on ebay. They are totally standard and 17000m miles apparently? They may do the trick? But then I am not a mechanic and mess up the threads on sauce bottles! _________________ Pomps
madasfook
Posted: Sun Nov 09, 2008 10:36 pm Post subject: |
i got a set of 42mm flat sides from my katana but i think they may not fit a water cooled _________________ so many toys so little time |
Posted: Mon Nov 10, 2008 7:26 am Post subject: |
| Pompey wrote: |
| Just had a quick look at a set of gsxr1100 M Mikuni 40mm carbs on ebay. They are totally standard and 17000m miles apparently? They may do the trick? But then I am not a mechanic and mess up the threads on sauce bottles! |
Thanks for that, already spotted them but the M model is oil cooled and I need a set for a water cooled. Different spacing unfortunatly  |
Posted: Mon Nov 10, 2008 7:27 am Post subject: |
| madasfook wrote: |
| i got a set of 42mm flat sides from my katana but i think they may not fit a water cooled |
Definatly too old skool to fit a water cooled  |
Admin Site Admin
Posted: Mon Nov 10, 2008 4:56 pm Post subject: |
To be honest, get the bike on a dyno. From memory part of the problem is the fuel pump and whether there is a return line. Think there was a fix to blank off the return line after the pump which resulted in severe over fueling when not at speed.
Keith |
Posted: Mon Nov 10, 2008 5:48 pm Post subject: |
Thank's keith but the fuel pump isn't even in the equation at the moment, I'm gravity feeding the carbs from a great height so no problem there. The problem is with the carbs and everything is wrong. Main jets, pilot jet's, air jet's, needles, emulsion tubes etc, etc and gawd knows what else has been done to them. I'm not so sure that the carbs are even off this bike anymore. The cheapest and eisiest way is probably a set of gixxer carbs and start from there
Spent most of the day ringing round the breakers and found a couple of sets but the bad news is, with vat and delivery, it's gonna knock a big hole in £200, ouch
At least I should be able to get it runing and THEN onto the fuel pump  |
Admin Site Admin
Posted: Thu Nov 13, 2008 1:15 am Post subject: |
Suspect someone has had a botched job at trying to sort the original problems.
Keith |
