![](images/avatars/119969225258aec84298c4c.jpg)
Posted: Wed Jul 14, 2010 12:29 pm Post subject: DB2 /3/4 front sprocket. |
Am in the process of changing chain and sprockets on my DB4. Have found out that the front is 95% 900ss , with and extra recess to allow the sprocket to move outboard on the output shaft. B&C express can not find anything to suite . Anyone had similar issues and know of a source. I believe DB2 and 3 are the same. |
![](images/avatars/19333637734f7adedb2675d.jpg)
Posted: Wed Jul 14, 2010 12:54 pm Post subject: |
Not quite sure what you mean about this "recess" but as an option, there's always the machining or adding a spacer options available ![Wink](images/smiles/icon_wink.gif) |
Posted: Wed Jul 14, 2010 1:23 pm Post subject: |
Ducati sprocket is flat on the front , and locking ring bolts to it. DB4 has a recess for the locking ring 3.5/4mm deep , so it moves the front sprocket outwards to align to rear. Problem with machining is they are hardened , so spark eroding only. Not the cheapest. |
Posted: Wed Jul 14, 2010 10:42 pm Post subject: |
They would only be case hardened so once that's been ground away..................... ![Wink](images/smiles/icon_wink.gif) |
Posted: Thu Jul 15, 2010 8:38 am Post subject: |
Just been reading a forum where it's common practice to machine front sprokets and even weld two together to make off set sproket's so, as I thought, they arn't that hard ![Wink](images/smiles/icon_wink.gif) |
deebee4
![](images/avatars/1391205131566f1ea99dbb3.jpg)
Posted: Sat Jan 08, 2011 7:15 pm Post subject: |
Hi, I remember getting a sprocket from the Ducati dealer after I showed them the db4 item and they came up with one that fitted quite well. Maybe one from a 9xx would work? _________________ Track riding on a Bimota: FUN! |
redtop
Joined: 04 Mar 2011 Posts: 13 Location: Stockholm, Sweden
Posted: Fri Mar 04, 2011 1:17 pm Post subject: |
The German company Wieres has the correct front sprockets for the DBs:
www.wieres.de
I bought a complete kit from them last year.
You can also machine a Ducati front sprocket to fit. Just bring the old sprocketet to a descent shop, or contact me and I'll be happy to send you a drawing. _________________ RedTop
DB2 #300 |
Desmo_Demon
![](images/avatars/12898119974ee83d162e2bd.gif)
Posted: Wed Dec 14, 2011 6:46 pm Post subject: |
I know this is an older thread, but I'll reply for any future searches on the subject....
redtop wrote: |
www.wieres.de
You can also machine a Ducati front sprocket to fit. Just bring the old sprocketet to a descent shop, or contact me and I'll be happy to send you a drawing. |
Redtop provided a schematic/drawing of the dimensions for the front sprocket and I had two machined to fit the OEM retainer. This is a picture of the machine work and the retainer that was on my '94 DB2...
You may need to correct me, but I have been told and seen in the parts manuals that the DB3/4 has a front sprocket that is similar to the one used on the Paso 750 and a few other earlier Ducati bikes. That sprocket looks like this....
This is the only picture I have of the one that was on my Paso 750, but I think you can see how it is recessed on the one side. This sprocket allows the use of a regular Ducati retainer. I'm thinking this is the route I may wind up going, some day, if I cannot find another OEM Bimota retainer.
On the other hand, rear sprockets are an off-the-shelf item. I know they are readily available from Vortex and Supersprox. I recently bought a Supersprox.
Edit - This is a picture of a stock Paso 750 sprocket that I pulled from the Ducati Paso forum...
![](http://i241.photobucket.com/albums/ff283/paso750/DSCF8461.jpg~original) _________________ Look for my books...
"If I Wrap It Tight Enough"
Posted: Thu Dec 15, 2011 2:37 pm Post subject: |
When I bought mine B&C express said they could not find a match, but maybe they just looked at the later stuff.
I had 2 spark eroded, but I guess in the future the paso knowlwdge will come in handy.
Thanks. |
