mainstone41
Posted: Sat Jun 15, 2013 8:28 pm Post subject: Fuel sender sb6 |
Hi has anyone sussed an alternative part for the fuel height sender?
Or anyone know where i could get a replacement as mines leaking fuel through where the wires enter! |
Posted: Sun Jun 16, 2013 1:17 am Post subject: |
The age old question... don't think anyones found a solution yet _________________ '99 DB4 #104, '96 SB6 #1165, '94 DB2 J #652, '99 DB4 #088, '08 VTX1800, '93 ZXR750R M1, '95 ZXR750, '95 ZXR750 Race Bike, '94 CBR400rr NC29 Race Bike, '94 CB250, '49 BSA C10 250, '61 BSA A10 650, '89 ZXR750, '91 Ducati 851 |
Posted: Sun Jun 16, 2013 7:07 am Post subject: |
...They are are pretty useless....
If it's working, it's only a matter of time untill it's not.
I thought I read on here that someone had found a replacement..Vince?, Mako?.
I just cut a blank out of ally plate and do without  _________________ SB6 mk1 (project mega light, big bore)
mainstone41
Posted: Sun Jun 16, 2013 9:47 am Post subject: |
oily wrote: |
I just cut a blank out of ally plate and do without  |
Rite were's that ally plate..? |
Posted: Mon Jun 17, 2013 7:23 am Post subject: |
I fitted a new one from that supplier- admitedly I had to file the float down a bit because it was slightly too big for the hole in the DB2 tank.
Sometimes the light is on, sometimes it's not.
I don't suppose it's the senders' fault- that's just the way they are : )
And now the thread of the YB4s' sender is weeping- so I'm not even going to fix that for the sake of the sender- just put the blanking plate back on . . .
http://thecrankcase.com |
Posted: Tue Jun 18, 2013 9:03 am Post subject: |
...One of my early SB6's came with a pre butchered sender that leaked. I found a replacement.......
...but that only lasted about 6 months so back to the blanking plate we went
Admin Site Admin
Posted: Tue Jun 18, 2013 7:45 pm Post subject: |
The size of the bolt on plate looks quite similar to that on the Cagiva Freccia. Anyone able to measure it up?
The Cagiva one is different inside but might do the job (on the Cagiva it is just a level switch, and the pipe is cranked as it goes in from the side of the tank).
Keith |
Posted: Tue Jun 18, 2013 8:47 pm Post subject: |
...overall length = 46mm
width at widest point = 19.5mm
bolt hole spacing = 34mm
bolt hole dia = 6.7mm
hole in plastic tank = 10.4mm
