whats its name??
PostPosted: Fri Jan 03, 2014 12:58 pm    Post subject: whats its name?? Reply with quote
Hi chaps
I'm looking for some of the rubber ring parts that fit around the fork leg in between the fork top and bottom yokes that cushion the forks against the frame on full lock. Anyone know what their proper name is and where I may be able to get them?? I know they are different sizes depending on fork diameter but first things first
cheers Question
PostPosted: Fri Jan 03, 2014 5:36 pm    Post subject: Reply with quote
according to the SB6/7 spare parts catalogue is referred to "Bumper"
I have no idea how to get them. Sad But let me know if you do.
vince
PostPosted: Fri Jan 03, 2014 8:43 pm    Post subject: Reply with quote
Some place like McMaster-Carr might have something that would work.
Spike C.
1965 Triumph T100SC
PostPosted: Sat Jan 04, 2014 1:05 am    Post subject: Reply with quote
I reckon youd be best off finding inch thick rubber sheeting and using hole cutter drill attachments to make outer and cut inner hole sizes...or foam pipe lagging and cable tie them on...
PostPosted: Sat Jan 04, 2014 1:11 am    Post subject: Reply with quote
Oh...Fork bump stops they;re called...like here on ebay
http://www.ebay.co.uk/sch/i.html?_odkw=bimota&_sop=10&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313.TR0.TRC0.Xfork+bump+stops&_nkw=fork+bump+stops&_sacat=0
Or here also if you just google "bumpstops" on ebay...
Which bike Nige, you dint mention a diameter...
http://www.ebay.co.uk/sch/i.html?_odkw=fork+bump+stops&_sop=10&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313&_nkw=bump+stops&_sacat=0
PostPosted: Sat Jan 04, 2014 10:37 am    Post subject: Reply with quote
yes seen them on ebay - they look a bit thin as they are for mountain bikes, but will have a look in nearest MBX shop.38mm for the KB1 - the Christmas boredom spanners came out of the drawer and the rest is history -ooops!! Very Happy
PostPosted: Sat Jan 04, 2014 12:08 pm    Post subject: Reply with quote
these look like they will do the job
I can only find 41mm diameter though
http://www.ebay.de/itm/390617036321?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
all the best
Ian
http://thecrankcase.com
Frank.61
PostPosted: Sun Jan 05, 2014 11:04 am    Post subject: Reply with quote
Hi Nige,
These maybe:
http://www.ebay.com.au/itm/MOTORBIKE-MOTORCYCLE-HEADLIGHT-BRACKET-RUBBERS-38mm-/390263530535 ?
Hope it helps!
Ciao,
Frank
PostPosted: Sun Jan 05, 2014 10:36 pm    Post subject: Reply with quote
Your better off sourcing some blocks of rubber and having them cut. Its not just getting the internal DOA right its the external which dictates the lock.
