Starting problem
JackJabba
PostPosted: Fri Sep 02, 2016 2:30 pm    Post subject: Starting problem Reply with quote
Hi Since getting the bike I have noticed that it doesn't crank over continuously until it starts. It cranks for about 2 seconds then stops if it hasn't fired into life. If I take the plugs out it will crank until you stop pressing the starter button.
Is this normal for the V DUE?
bannrikae
PostPosted: Fri Sep 02, 2016 7:35 pm    Post subject: Reply with quote
Sounds like the sprag clutch, I had the same problem.
Have a look at the thread also called "starting problem" about halfway down the page.
BG
JackJabba
PostPosted: Fri Sep 02, 2016 8:39 pm    Post subject: Reply with quote
Thanks, I have now read your thread, don't know how I missed it and it looks like the same problem you had in the second video of it not starting. i will drop the oil tomorrow and take a look.
PostPosted: Fri Sep 02, 2016 11:43 pm    Post subject: Reply with quote
Sprag clutch ?
Cheers Trev
PostPosted: Sat Sep 03, 2016 6:55 am    Post subject: Reply with quote
Yup - welcome to the Vdue!
JackJabba
PostPosted: Sat Sep 03, 2016 2:58 pm    Post subject: Reply with quote
Just dropped the oil out and and no bits of metal stuck to the magnet.
PostPosted: Sat Sep 03, 2016 8:43 pm    Post subject: Reply with quote
All depends how bad it is, sprag housing may just be loose and if so might spin over a few times until bearing twists slightly and then locks up ??? Crying or Very sad
But then can also be a bad earth, battery a bit weak, etc etc.
