Posted: Thu Jun 28, 2012 2:03 pm Post subject: More carbon........ |
...Can you handle more carbon?...
Would anyone be interested in a rear brake master cylinder cover in carbon?
This one is on a SB6 but should fit most brembo cylinders with this bolt spacing...
...Just to make it clear, this is the master cylinder cover only and NOT the foot rest hanger.
Preliminary negotiations will put these at about £45 each but if there's a big demand the price will come down
Will certainly fit SB6, SB7, SB6R and I'm sure the doochatee boys will chime in with there views
Shout up if your interested and I'll start a list to see if it's worth while
P.S 40mm bolt spacing, just measured
oily X 2
Bimototo
2bims X 2 _________________ SB6 mk1 (project mega light, big bore)
SiBag
Posted: Thu Jun 28, 2012 3:57 pm Post subject: |
Bizzarly Im presently over at the Hethel Engineering Centre in Norfolk.
About 1 mile from the Lotus factory.
Im training a load of bods from Carbon Fibre Technologies how to drive their new CAD system.
I dont think they do any SB6 stuff though, otherwise I would try and blag a load of bits.... _________________ Si...
Posted: Thu Jun 28, 2012 4:14 pm Post subject: |
We use CAD - we've just gone to 2012 AutoCAD and most people dislike the ribbon interface. It crashes a lot too. _________________ Don't read everything you believe |
Posted: Thu Jun 28, 2012 4:17 pm Post subject: |
Yep, everyone uses cad these days so are you interested or not?
SiBag
Posted: Thu Jun 28, 2012 4:40 pm Post subject: |
oily wrote: |
No thanks,
Not keen on the design, hides too much... And yes I know thats probably the idea......
Evilchiken, you need a propper 3d system......  _________________ Si...
bimototo
Posted: Thu Jun 28, 2012 8:18 pm Post subject: |
it will be ok also for db4, I'm interested in one  _________________
Posted: Thu Jun 28, 2012 8:24 pm Post subject: |
SiBag wrote: |
No thanks,
Not keen on the design, hides too much... |
Yep.....as you walk around the SB6, there is only one spot on the whole bike that looks unfinished/untidy......and this hides it....too much?
P.S.
Bimota realised this when they designed the SB6R as they moved the reservoir out of sight, and fitted a heel plate to hide the master cylinder.........
hides too much?........  _________________ SB6 mk1 (project mega light, big bore)
mainstone41
Posted: Thu Jun 28, 2012 10:43 pm Post subject: |
Rob that heel plate looks the bollocks! Oh hold on its mine! lol |
Posted: Thu Jun 28, 2012 11:35 pm Post subject: |
I've seen one on another SB6 at Race Engineering ... not really that keen on it. _________________ Don't read everything you believe |
MARTIN
Posted: Fri Jun 29, 2012 7:38 am Post subject: |
The very mention of the word CARBON has some bimotski`s drooling.
So to add to your fetish, here is another piece of porn to lick
http://raresportbikesforsale.com/carbon-dreams-2000-bimota-sb8r-special/
Remeber to wipe the screen when you have finished  _________________ Marty
Posted: Fri Jun 29, 2012 12:48 pm Post subject: |
Hi Oily, I'd be up for 2 please, They also Fit YB11, as mine came from a YB11, and the YB11's don't have a heel guard and your boot constatly rubs against the rubber cap of the rear brake light pressure switch (re banjo switch cover) I have one but its damaged and would like more.
They also fit Db2's also, as they have no heel guard either. They also fit Db4 as they all use the same spacing for the rear brembo master cylinder, although on the Db4's there should be a heel guard (alloy) in place already.
So 2 for me, I'm sure Vort will be up for some also, |
morepower
Posted: Fri Jun 29, 2012 2:03 pm Post subject: |
Just looked at this thread..... What about a modified design. Make it more like a heel guard and put a cut out in the centre of the cover? You can make changes to it as long as the basic shape stays the same...
Posted: Fri Jun 29, 2012 2:45 pm Post subject: |
OK.....ignoring the previous post.....if you want them modified, we'll sort that after you've bought a standard one  _________________ SB6 mk1 (project mega light, big bore)
Posted: Fri Jun 29, 2012 2:48 pm Post subject: |
I'm thinking ...... same carbon as the hugger
list they will fit so far.....
SB6
SB7
SB6R
DB2
DB4
YB11
List of interested parties so far
bimototo
2bims X 2
oily X 2
Posted: Fri Jun 29, 2012 3:45 pm Post subject: |
me x 2 ... _________________ Pomps
