Sprag clutch.
JackJabba
PostPosted: Sat Sep 03, 2016 6:15 pm    Post subject: Reply with quote
Cant see the pictures, probably because its such an old post, do you still have them?
PostPosted: Sat Sep 03, 2016 8:33 pm    Post subject: Reply with quote
Pictures got lost when the forum went down once, I will have a look for them but what exactly are you after seeing , as might have others.
JackJabba
PostPosted: Mon Sep 19, 2016 4:38 pm    Post subject: Reply with quote
Was wanting to see what it all looked like once the the clutch was off and then the sprag clutch.
I can message you my Email address so you don't need to re post.
PostPosted: Mon Sep 19, 2016 6:16 pm    Post subject: Reply with quote
Struggling to find the original pictures. Will have another look
JackJabba
PostPosted: Fri Oct 07, 2016 4:51 pm    Post subject: Reply with quote
Does anyone know which tool I need to get the clutch center nut off. I have a holding tool.
bannrikae
PostPosted: Fri Oct 07, 2016 8:48 pm    Post subject: Reply with quote
Managed to get mine off with a hammer and punch although it did damage the nut a bit and I brought the last spare nut off of Piero.
I ended up ordring a socket for a ford transit to put the nut back on, I think it was this one.
http://www.paddockspares.com/lock-nut-socket-ford-transit.html?gclid=CjwKEAjwj92_BRDQ-NuC98SZkWYSJACWmjhl-kylGqNSDx9zU-Jolh_knpdAaeTi3TF-i7TfNlS7kRoCUo7w_wcB
Hope this helps.
BG
JackJabba
PostPosted: Sat Oct 08, 2016 11:01 am    Post subject: Reply with quote
That's a great help.
Thanks Jack
bannrikae
PostPosted: Sun Oct 09, 2016 9:42 pm    Post subject: Reply with quote
No problem, looks like I have to do mine again.
Simon51
PostPosted: Mon Oct 10, 2016 3:34 pm    Post subject: SPRAG CLUTCH Reply with quote
i'v just repaired my sprag clutch, got a new, looks updated bearing and cover from piero last week, fitted it and it started first time.. buzzing!!
S harris
JackJabba
PostPosted: Wed Oct 12, 2016 6:49 pm    Post subject: Reply with quote
Does the engine oil need to be dropped as well as the coolant? Doing mine this weekend.
PostPosted: Wed Oct 12, 2016 8:54 pm    Post subject: Reply with quote
Yes, oil out.
If you drop the engine slightly you can leave the clutch assy together, if you do in situ you have to remove clutch basket and round nut at bottom of basket . This will be thread locked on so requires heat to melt thread lock.
JackJabba
PostPosted: Sun Oct 23, 2016 4:09 pm    Post subject: Reply with quote
Fitted the Sprag bearing, bike fired up first hit of the button . Happy days.
Just need a Carbon clutch cover to finish the job off.
PostPosted: Mon Oct 24, 2016 11:20 am    Post subject: Reply with quote
Mine is getting gloss lacquered as we speak.
Have asked him for a price for a batch of 10
bannrikae
PostPosted: Mon Oct 24, 2016 7:23 pm    Post subject: Reply with quote
Just purchased my carbon clutch cover from the states.
Cant wait to fit it Very Happy
JackJabba
PostPosted: Mon Oct 24, 2016 9:23 pm    Post subject: Reply with quote
I will wait for a UK manufactured one. I just can't get over paying duty on postage for goods from the States as well as import duty.
On another note, my friction plates look like they are made of a copper coloured material and have no friction material on them like a wet clutch, is this normal?
Page 2 of 3
