More carbon........
Goto page 1, 2, 3 ... 9, 10, 11  Next
PostPosted: Thu Jun 28, 2012 2:03 pm    Post subject: More carbon........ Reply with quote
...Can you handle more carbon?...
Would anyone be interested in a rear brake master cylinder cover in carbon?
This one is on a SB6 but should fit most brembo cylinders with this bolt spacing...
...Just to make it clear, this is the master cylinder cover only and NOT the foot rest hanger.
Preliminary negotiations will put these at about £45 each but if there's a big demand the price will come down Wink
Will certainly fit SB6, SB7, SB6R and I'm sure the doochatee boys will chime in with there views Wink
Shout up if your interested and I'll start a list to see if it's worth while Wink
P.S 40mm bolt spacing, just measured
oily X 2
Bimototo
2bims X 2
SiBag
PostPosted: Thu Jun 28, 2012 3:57 pm    Post subject: Reply with quote
Bizzarly Im presently over at the Hethel Engineering Centre in Norfolk.
About 1 mile from the Lotus factory.
Im training a load of bods from Carbon Fibre Technologies how to drive their new CAD system.
I dont think they do any SB6 stuff though, otherwise I would try and blag a load of bits....
Si...
PostPosted: Thu Jun 28, 2012 4:14 pm    Post subject: Reply with quote
We use CAD - we've just gone to 2012 AutoCAD and most people dislike the ribbon interface. It crashes a lot too.
PostPosted: Thu Jun 28, 2012 4:17 pm    Post subject: Reply with quote
Yep, everyone uses cad these days so are you interested or not?
Rolling Eyes
SiBag
PostPosted: Thu Jun 28, 2012 4:40 pm    Post subject: Reply with quote
Rolling Eyes
No thanks,
Not keen on the design, hides too much... And yes I know thats probably the idea......
Evilchiken, you need a propper 3d system...... Wink Wink
Si...
bimototo
PostPosted: Thu Jun 28, 2012 8:18 pm    Post subject: Reply with quote
it will be ok also for db4, I'm interested in one Wink
PostPosted: Thu Jun 28, 2012 8:24 pm    Post subject: Reply with quote
SiBag wrote:
No thanks,
Yep.....as you walk around the SB6, there is only one spot on the whole bike that looks unfinished/untidy......and this hides it....too much? Rolling Eyes
P.S.
Bimota realised this when they designed the SB6R as they moved the reservoir out of sight, and fitted a heel plate to hide the master cylinder.........
hides too much?........ Rolling Eyes
mainstone41
PostPosted: Thu Jun 28, 2012 10:43 pm    Post subject: Reply with quote
Rob that heel plate looks the bollocks! Oh hold on its mine! lol
PostPosted: Thu Jun 28, 2012 11:35 pm    Post subject: Reply with quote
I've seen one on another SB6 at Race Engineering ... not really that keen on it.
MARTIN
PostPosted: Fri Jun 29, 2012 7:38 am    Post subject: Reply with quote
The very mention of the word CARBON has some bimotski`s drooling.
So to add to your fetish, here is another piece of porn to lick Razz
http://raresportbikesforsale.com/carbon-dreams-2000-bimota-sb8r-special/
Remeber to wipe the screen when you have finished Razz
Marty
(00) SB6 (95) HD FXDWG STRETCH (01)GSXR1000K1
PostPosted: Fri Jun 29, 2012 12:48 pm    Post subject: Reply with quote
Hi Oily, I'd be up for 2 please, They also Fit YB11, as mine came from a YB11, and the YB11's don't have a heel guard and your boot constatly rubs against the rubber cap of the rear brake light pressure switch (re banjo switch cover) I have one but its damaged and would like more.
They also fit Db2's also, as they have no heel guard either. They also fit Db4 as they all use the same spacing for the rear brembo master cylinder, although on the Db4's there should be a heel guard (alloy) in place already.
So 2 for me, I'm sure Vort will be up for some also,
morepower
PostPosted: Fri Jun 29, 2012 2:03 pm    Post subject: Reply with quote
Just looked at this thread..... What about a modified design. Make it more like a heel guard and put a cut out in the centre of the cover? You can make changes to it as long as the basic shape stays the same...
PostPosted: Fri Jun 29, 2012 2:45 pm    Post subject: Reply with quote
OK.....ignoring the previous post.....if you want them modified, we'll sort that after you've bought a standard one Laughing
PostPosted: Fri Jun 29, 2012 2:48 pm    Post subject: Reply with quote
I'm thinking ...... same carbon as the hugger Wink
list they will fit so far.....
SB6
SB7
SB6R
DB2
DB4
YB11
List of interested parties so far
bimototo
2bims X 2
oily X 2
Cool
PostPosted: Fri Jun 29, 2012 3:45 pm    Post subject: Reply with quote
me x 2 ...
Page 1 of 11
